lsintoronto
Trying to remove the glove box on my '04 LS and having difficulty seeing what's holding the door in place so I could lower it to get at the 3 bottom screws for removal. I removed the side panel by the door and could see the stop arms and "released" them (from a guide I think as I couldn't see) by pushing outward on them. i could not see an "assist cable" attached to them that had to be released though. This was last night as light was fading at dusk so going to revisit now.
Is there a trick to this? The instructions in deneau.com doesn't have the step for the glove box door arms.
SECTION 501-12: Instrument Panel and Console
2006 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 06/24/2005
Glove Compartment Printable View (8 KB)
Disconnect the battery. For additional information, refer to Section 414-01 .
Remove the instrument panel trim panel.
Release the glove compartment arm assist cable from the assist arm.
Lift up on the glove compartment door assist arms and lower the glove compartment.
Remove the 2 glove compartment assist cable bracket screws.
Remove the 5 screws and the glove compartment bin.
Disconnect the glove compartment lamp electrical connector.
Remove the 5 bolts and the glove compartment door frame.
To install, tighten to 5 Nm (44 lb-in).
To install, reverse the removal procedure.
