Got Me!!!
KC96LSC
Kansas City
I put new front struts on(Tuesday. Great no problem. Then today check air ride. Back left is new aswell. Right side does not go up the front goes all the way up, then you hear a switch turn on sound and the r/rear goes a little bit then stops. after a minute front R comes down to normal. But front left stays all the way up. Any Ideas.
Thanks for any help
from what i have heard that sound right
what mike sed
also mike just be a wire maybe you didnt hook it up right
Did you replace the "O" Rings for the solenoids. Most of the time they need to be changed out when you put in new bags, even though they may look OK they actually leak. Also when installing the new ones use some dialectric gease to help lube them .
Guys Thank you for your input. I feel like an idiot. After I wrote this I took a closer look and realized that my front height sensors bolt had worked it way out. Which caused the air bag to inflate all the way. Which intern made the back right side look slammed. I hope that will be the end of it. I do appreciate you guys responding to my questions.
Greg
