keatonsdad
I know alot of us here have used their GPS to verify our speed, but would it be able to be used as a defense in traffic court if need be? Would it be more accurate than the laser and radar that the police use?
Last I checked, hertz are cycles per second, so that would be 60 times per second...Commercial GPS receivers update at 60hz. That's once per second.
Most GPS units are accurate to within 0.1kt (at least according to all of the specs I've checked), so that's not really an issue. The bigger problems are how frequently, if at all, the GPS unit records the data, and how to verify that the data has not been altered. It would be possible to build a GPS device that can do that by writing the data to a SanDisk SD WORM card (which, after all, is designed for that purpose), but I don't know if any do that kind of datalogging.I would tend to agree with the Frog. Not only are the in-car GPS units less accurate than police radar but how would you use the in-car unit to prove you innocence?
I know mine (Garmin Nuvi 255W) does route tracing, but the only data I could get off of it was endpoints and arrival/departure times. Average speed is interesting, but I'm thinking it probably won't help if you're trying to beat a ticket...A lot of them do. Hell, even the factory one in my F450 has a "breadcrumb" function. But you have to enable it, it doesn't do it automatically.
