grrrr
00ls-sport
Lunenburg, MA
installed the factory sub, whci hwas a complete pita, put interior back together. plugged into oe harness.....and nothing. wtf. i know i don't have the audiophile system, but the connector was in the trunk, so i assumed the woofer would work. am i forgetting something(fuse, relay), or am i sol?
IIRC only the audiophile system had the rear sub connector on the factory head.
Pull the head out - that will show the connector for sure.
On audiophile systems, there is an 8-pin connector wired as follows:
position 1 = sub + line level signal (gray/red)
position 2 = sub - line level signal (white/red)
position 3 = shield for sub amp signal
position 4 = +12 remote power to sub amp (yellow/red)
position 5 = center channel - line level signal (gray)
position 6 = center channel + line level signal (white)
position 7 = shield for center channel signal
position 8 = +12 remote power to center channel amp (yellow)
so, unless i get an audiophile head unit, im still SOL! what a pain! that was not an easy job, and now i will have to do it again to take it out. :rolleyes:
not sure - I would invest in the extra 15mins and pull the head unit to look for the connector.
