had a question about camber
jony
Orlando
so im currently looking to buy a lincoln ls, think i found the one i want to buy an its a 03 silver gen 2 with all the goodies... (no lse do) ;(
at any rate i bought some silver JAGUAR XF CARELIA 19in rims on cl that i will want to install on my new ride when i get it...
my question is, is it easy to adjust camber on the ls? will i need camber brackets or a camber bolt kit to accommodate?
any input would be appreciated, thanks!
I think you will be fine as long as the car is aligned UNLESS you get it lowered.
If you are going for the flush look good luck. The camber adjustability is almost none and the rear does not have any kits available. If you look for the coil over thread it gets into more detail about it
