amorgan2017
Hey guys, been putting it off for awhile now but i have some sort of handling issue. I know the LS rides a little rough on the bumps which I'm fine with. I put base instead of sport suspension when I got it. But I'm wondering if it's normal when you hit bumps where it occasionally pulls the wheel sorta. Hard to describe it I don't mean pull but jugs the tires a bit. It's also really bad at high speeds. I'm not talking 100+ I mean like 70-90. You feel like you're floating and it drifts you all over with a firm grip on the wheel. I know the floating feeling you feel in your old Impala at 100+ is normal but should I be feeling that at 70-80? Anyway it's kinda hard to drive on the freeway without a white knuckle grip on the wheel so anyone with advice I'm willing to listen/ do whatever it takes.
Thanks!
Thanks!
