most egr valves are ok its the egr back psi transducer or DPFE it is on the back of the driver side head when exhaust runs through it it makes the sensor go bad causing the computer to think the egr valve is open auto zone sells egr's to everybody that gets this code (every ford) and they come to the dealer to have us install it and we have them take it back and replace the DPFE and then its fixed. with the new egr the code will come back right away
Section 03-08: Engine Emission Control 1996 Mark VIII Workshop Manual
IN-VEHICLE SERVICE Procedure revision date: 05/18/2000
EGR Backpressure Transducer
Removal and Installation
Remove engine appearance cover, air cleaner outlet tube (9B659) and engine intake air resonator (9F763) as outlined in Section 03-12.
Disconnect fuel charging wiring (9D930) from EGR backpressure transducer.
Disconnect EGR backpressure transducer hoses from EGR backpressure transducer.
Remove EGR backpressure transducer retaining nuts and EGR backpressure transducer from EGR backpressure transducer bracket.
If required, remove EGR backpressure transducer bracket from the LH cylinder head (6049).
To install, reverse Removal procedure. Tighten EGR backpressure transducer bracket bolts to 8-12 Nm (71-106 lb-in). Tighten EGR backpressure transducer retaining nuts to 5-7 Nm (40-61 lb-in).
Item Part Number Description
1 N620479-S50 Nut (2 Req'd)
2 9J460 EGR Backpressure Transducer
3 9J472 EGR Backpressure Transducer Bracket
4 6049 LH Cylinder Head
5 N606676-S36 Bolt (2 Req'd)
A — Tighten to 5-7 Nm (40-61 Lb-In)
B — Tighten to 8-12 Nm (71-106 Lb-In)
---------------------------------------------------------------------------its a small steel box with 2 small rubber hoses on it (dont get the 2 confused one is high and one ref) and a grey 3 pin oval shaped connector on the 96 100% sure straight from the fmc dealer website
