I have a 92 Mark VII. had it for about 2 years. I had some problems with it but nothing I couldn't figure out. I was noticing my AMP light coming on and going off. As I was checking under the hood I saw a wirer from the starter relay was severed and melted to another piece of metal. I tried to splice and connect the two. It worked for awhile but it seems once the car heats up a bit the connection seems to loosen. Anyway this wire goes into a connector wire along with four others. It is connected to the starter relay. Does anyone know what kind of wire this is and where I might find one. Or if there maybe another way around it??
