shokher
how do i keep my low beams on when i turn on my hi beams? i want them both on be on since my lows are xenon (converted) and i just want the highs to supplement them.             2002 ls v8
			never heard such a thing.Cruznlife1 said:what people dont understand is you'll see less with both lights on. thats why the kits for the s10 and stuff are so worthless. If your highbeams are on, low beams go off, it takes the light off the ground, and throws it ahead of you. if the lows stay on and theres so much light on the ground, even wiht the high beams on you wont see that far ahead. it'll be brighter but you wont see as well as you would with the low beams off. and HID cars only keep the lowes on so you dont damage the lights by constantly turning them off and on when you use your highs.
Your wrong. All you have to do is install one of those "worthless kits" and you'll see that your wrong. You can still see just has far with highs and lows on vs just highs. I did the relay install kit and I can tell you it was a night and day difference when I used the highs on my chevy pickup, then I added KC daylighters and you can really see farCruznlife1 said:what people dont understand is you'll see less with both lights on. thats why the kits for the s10 and stuff are so worthless. If your highbeams are on, low beams go off, it takes the light off the ground, and throws it ahead of you. if the lows stay on and theres so much light on the ground, even wiht the high beams on you wont see that far ahead. it'll be brighter but you wont see as well as you would with the low beams off..
