heat/AC
CFH
Santa Cruz
well, i dunno if its a problem but my heater lights have been blinking lateley, sometimes they would stay on solid, but most of the time they would blink, the heater works fine, i havent really had A/c since i bought the car but i would turn it on cuz it would work as a great heater.
also how hard is it to find something to plug my memory wire in my cd player into? im kinda not sure whats up wid dat. thanks dudes!
Use this for the Automatic Temperature Control: http://www.lincolnsonline.com/tech/00007.html
For the stereo I am assuming that your "memory wire" is the constant 12V line that is used to save things like the time and radio stations. If this is the case there is a wire designated for this that goes to the stereo. If you did not get an aftermarket adapter to connect your stereo and just hacked the wiring you will need to determine which wire that is left provides a constant 12V with a voltmeter.
