Heat Help
LSCPlayer
Fishkill
Hello all,
I have an issue with the heat in my '92 Eldo. It only comes out warm on the passenger side of the car. The blower functions just fine but on the drivers side it blows cold air and the passengers side it blows "warm" (not hot) air. I'm thinking it is a couple of things and just want some opinions. I think the problem with where the "heat" is blowing is the blend door actuator. I think it's either disconnected or just broken. As for the degree of heat, I think it's the heater core (I hope not), although the hoses come from and going to get hot plus there is no leaking anti-freeze on the passenger side floor nor a anti-freeze smell in the car. Please chime in with your opinon as to what my problems are and possible fixes.
Thanks in advance,
LSC Playa/Snoop
had same problem with my .car pass hot driver cold it was the actuator motor for thew middle door (around$300) for dealer to fix.as far as how hot it gets is your coolant full? also check your thermostat good luck let us know how you make out
my mistake it was $225 to repair
Thanks for the reply. Turns out it was the heater core ($225 cost to replace).
