When I took the car to the shop, the guy told me the heater core was leaking. I was surprised about that and couldn't believe it at first. But sure enough, when I got the car back it was steaming up the windows.
Having replaced a really corroded radiator (likely the original one) a couple years ago, my guess is the heater core is in equally bad shape. I dumped one tube of Bar's powdered stop leak in it today... good luck with that.. but it might help for a little while..
Aside from the work and time, I don't think this old car will survive a dashboard R&R. Lots of rubber parts are getting slightly brittle with age. Mechanic wants $800.
There is also a faulty plenum mixture door. I can live with that. But I gotta have a heater.
I was reading various webpages and one guy had (i think) a Mustang, and talked about cutting away the plastic shielding under the dashboard, behind the glove box, to access and replace his heater core. Interesting idea.
Anybody think this is possible on the '88 Mark 7?
EDIT
ok.. it was a dumb idea to post that question without first taking a look at where the core is. No reason to quit while I'm behind, so here's another dumb idea.
Looking under the hood, I see the core's tubes extend through the firewall where the hoses attach. It's high up on the wall. The area is fairly accessible.
Suppose one were to cut a rectangle out of the firewall's sheet metal, big enough to pull the core straight forward and into the engine compartment. It would hit the throttle body, but that can be removed. It's a fairly clear shot that in theory, looks possible.
I'm holding a new core. It has flanges... and they are probably screw-attached to something.
Question is, is this core absolutely secured inside it's housing, and so cannot be pulled out? Or are the heavenly stars aligned and the core only fits snugly in a soft, rubber cushion?
i really really don't wanna do all the things required to replace this..
I know where Lincoln can stuff their core next time around..
EDIT
