Don H
Hi everybody, I came across this site while searching for info about Mark viii computer wiring and thought I would check it out. I am building a custom 1969 ford truck for my son and am using a 1995 Mark viii as a donor for the engine, transmission and rearend. It also has an independent front suspension from a 05 crown vic. As it sits I have the front suspension mounted, engine/transmission mounted and the rearend mocked up ready to fabricate things. I will hopefully be able to use the wiring harness from the Mark viii to make this run and shift. I will be asking alot of questions and hopefully answering many too. Look forward to being a part of this.
Don
Don
