Help 2000 NAVI garage door opener
simplex
san lorenzo
Hi,
i lost my instruction how to program the remote comander. anybody
have one, post it PLEASE.
thanks
simplex said:
Hi,
thanks
Not sure if it's the same but this is how you program an 03.
1. Press and hold the two outside
buttons releasing onlywhen the red
light begins to flash after 20
seconds. Do not repeat step one to
program additional hand-held
transmitters to the remaining two
HomeLink buttons. This will erase
previouslyprogrammed hand-held
transmitter signals into HomeLink.
2. Position the end of your
hand-held transmitter 2–8 cm (1–3 inches) awayfrom the HomeLink
button you wish to program (located on your visor) while keeping the
red light in view.
3. Simultaneouslypress and hold
both the HomeLink and hand-held
transmitter button. Do not release
the buttons until step 4 has been
completed.
Some entrygates and garage door
openers mayrequire you to replace
step 3 with procedures noted in the
“Gate Operator and Canadian Programming” section for Canadian
residents.
4. The red light will flash slowlyand then rapidly. Release both buttons
when the red light flashes rapidly. (The rapid flashing light indicates
acceptance of the hand-held transmitters’ radio frequencysignals.)
5. Press and hold the just-trained HomeLink button and observe the red
light. If the light is a constant red, programming is complete and your
device should activate when the HomeLink button is pressed and
released. Note: To program the remaining two HomeLink buttons,
begin with step 2 in the “Programming” section — do not repeat step 1.
Note: If the red light blinks rapidlyfor two seconds and then turns to a
continuous red, proceed with steps 6 through 8 to complete
programming of a rolling code equipped device.
6. At the garage door opener receiver (motor-head unit) in the garage,
locate the “learn” or “smart” button (usuallynear where the hanging
antenna wire is attached to the unit).
Driver Controls
136
7. Press and release the “learn” or “smart” button. (The name and color
of the button mayvarybymanufacturer .)
Note: There are 30 seconds in which to initiate step eight.
8. Return to the vehicle and firmlypress, hold for two seconds and
release the HomeLink button. Repeat the press/hold/release sequence
again, and, depending on the brand of the garage door opener (or other
rolling code equipped device), repeat this sequence a third time to
complete the programming.
HomeLink should now activate your rolling code equipped device. To
program additional HomeLink buttons begin with step 2 in the
“Programming” section. For questions or comments, please contact
HomeLink at www.homelink.com or 1–800–355–3515.
simplex said:
Hi,
thanks
I'm not sure if you know this but if you register your navigator under the lincoln owner link at www.lincoln.com you can access the manual online.
