tom8214003
So I got everything together with the new custom made airstruts from Airbagit.com and the damn system leaks still - the car raises like normal and then within 2 hours back on the ground. So there's got to be a slow leak that I cannot hear between the 4 points. I got a feeling its somewhere on the solenoid or where the factory plastic airline goes into the solenoid. I had a hard time getting the "quick-connect" fitting into the new solenoid (made by Arnott ind.) and it didn't go down all the way as if its just too big for the hole. Should there be some kind of positive clicking action when inserted?? This sucks!! Took me 15 mins to swap out the struts but over a week messing with with this custom airline b.s.!!
Some background -I had went on Airbagit.com - and ordered the OE style Weston Industries built struts they had listed in their catalog online. I paid for them and a couple days later they call me back to say that its not in stock (no surprise) - and offered me a solution. They said they make their own custom direct fit air struts with an air line adapter and fitting etc.. and although its listed as double the cost - like $450 each side, because of the circumstances, they could offer these for the same price I had already paid. I knew it was going to be nearly impossible to get new struts unless actual Ford OEM replacements at over $600 each - so I said okay hoping that there wouldn't be any issues installing them. The salesman Tom P. says its a direct fit no fabrication necessary! - also says that they have a lifetime warranty on the airbag from leaks.. two weeks later I'm still working on this! No official instructions -just emails back and forth with the sales guy Tom Parkinson. I had to buy longer bolts and add washers for spacing and try a variety of fittings to make the airline hose reach. I've considered using a 3/8 braided hose for a dishwasher but its not NPT I dont think.
