Help!! frond end down
joeydm090682
woodbridge
had to get towed home from LBI front end wont lift up bags are new cant find any leaks, the air pup runs than i here a click is sounds like the valve that lets air into the front bags wont let air in. any suggetions will help thanks
I had this same problem. Changed over to springs on my 93.
If you become a gold member you can get great discounts from the vendors to make the change less expensive. $350 - $400.
Conversion is simple and takes only about 1 to 2 hours.
Otherwise I'd get in touch with Eddie (screen name - American Air-1) at American Air Suspension www.americanairsuspension.com .
Eddie will give you the best answers just give him a call. He's not out to sell you products but he has them available if you need them.
you sed you just put 2 new bags in the front right
if that so talk to kieth at BagMaster i think it might be the solinoid might be rong
Do a goodgle search for BagMaster there in Texas they have a help forum but they reman all suspension parts for lincoln
What year is the car? is it a mark vii? if so you could had filled it up at a gas station. the valve in the engine comparment, But you need to know the code to get each individual bags up. first the lose wire by the air bag switch neeed to be place on the screw near the switch. then turn key to right, with engine off, wait 3 or 5 seconds then open and close the diriver door for each bag.
well it turns out to be the air pump, i just got the old one out, had to take the front bumper off and side lights, what a job! lol the pump that was in there had a date on it of july 03 it said arnott inc on it, i thought arnott was supposed to be a good brand. new one comes tomorrow. so thanks for your help guys
