Hey Guys,
Bought 2001 Lincoln LS V8 at auction with 190k miles. No history on the car. Fan is not kicking in to high speed. Mechanic says it does spin slowly. Ordered a used Actuator off ebay. Still no change!! I had the mechanic disconnect the plug around the*coolant crossover pipe*on the driver's side. I read on this forum that should trigger the fan to high speed.Still no change! Fan does work. Just doesn't move fast enough to cool the car. Mechanic does not know how to test. So I'm coming to you guys! Is there any way to test the parts before I just start throwing stuff at it?? Im thinking of buying a fan motor next. I also read on this forum, if the fan spins at all, the pump is likely not to be the problem. Any advice would be greatly appreciated.
