gdubya
While changing my plugs and wires (troubleshooting a misfire on #2) on my 1997 continental, I accidentally leaned on a vacuum tube and a plastic t-connector snapped right off into 3 pieces. It is mounted under a plastic housing under the lip of the engine compartment right in front of the firewall. It connects on the engine to a flexible tube in the middle of the manifold, on the passenger side to a semi-rigid tube to a check valve of some sort, and on the drivers side to a module that has multiple connections labeled S (that's the one it connects to) B/R L E B/B. No surprise, it startes to die right after starting up.
What does this thing connect to on the motor? Does anyone know if I can get replacement T (what size is it) and can I get replacements for the semi-rigid vacuum tubes, since I am having a heck of a time getting the broken T-connector out of one.
I hate when my own clumsiness causes problems worse than what I started with.
I can't take any pictures right now, since (of course) I'm supposed to be headed out of the house. I'll have to pick it back up in the morning.
