Help I need a picture of the passenger side front body mount
purelux
I had my car back to the body shop and now there is a rubber mount under and above the frame but a probably at least 1" gap between it and the body. Which you can clearly see the ring from the spacer or shim from before. I measured the front and the right side is an inch or so lower as well. I am going to go back on monday if possible with a picture of what needs to be there. I found an illustration but a picture would be very helpful. At first they tried after the vehicle was repaired saying I didn't really need it.
