Lincolnlov
Drove my 1990 Mark home from work this afternoon and found my self with a really wierd problem. I could not turn the ignition off! Tried shifting from park to low and back again several times. Tried turning the steering wheel. Tried driving around the block -- all without any change in the situation.
Finally I disconnected the coil to stop the motor and then disconnected the battery. All stopped. Then, I tried reconnecting -- no change, and re-starting--still no change. So I stopped the motor as before and again disconnected the battery. I'm wondering if there is some sort of control at the shift lever that I might need to deal with but don't have any knowledge about that. Any ideas that you guys might would sure be welcome. I need to use the car to go to work tomorrow.
