Help! MarkVIII Wiring through firewall!!
comfyseats
fortwalton beach
I have a 97 Mark VIII and I am trying to find a spot to run my 2AWG from the battery through the firewall? Has anyone else had success finding a good spot without drilling a new hole on this vehicle?
Can you not run it in thru the main wiring harness just below the brake booster? The opening under the brake booster is nothing more than a rubber cover with the wiring running thru the firewall to the fuse panel and dash electronics and ECU, there is enough room for you to push the wiring thru there.
Me also.. I have a half dozen wires going through there...
Staff online
