rg200amp
Hello all. I have a iddse I need help with.
2004 LS V8 with 3.8l with 87,000 miles.
My front passenger side window was down all day. I went to roll it up and I heard a loud CRACK and now the window will not roll up. The glass is not broken. I think the glass fell out of the tracks. I can not see or touch the window from the gasket. This leads me to think it fell out of the track.
I searched TSBs but I did not see anything. Anyone know anything about this???
Also. I have a issue with my heat/cool seats. When I turn the heat or cool on it will stay on for like 1-2 min. Then it will shut off. It will not allow me to turn them back on. When I hit the button to turn them on, the green lights just blink once, and it remains off. I have on lights or warnings on.
I found this:
TSB Number:040402 NHTSA Number:10013114 TSB Date:January 1, 2004 Date Added to File:April 8, 2005
Failing Component:
Seats: Front Assembly Seat Heater/Cooler
Summary:
Climate controlled seats turning off shortly after initialization - diagnostic trouble codes B2729, B2730, B2731.
Will Ford fix this issue for free?
THANK YOU ALL FOR THE HELP YOU CAN GIVE!!!
I found this:
Failing Component:
Summary:
