help no air from dash vents
guy64
roseville
yep no air thru dash vents!!! floor works defrost works no dash vents help anyone!!!!!1
thanks
sounds like a vacuum leak, I had something similar except my dash vents would work for a few minutes when the car started then it'd switch to defrost and the dash wouldn't work anymore. I had to take apart the glovebox and crawl under with a flash light to look up into the dash and look for the vaccum line that had come undone. Could very well be the same problem as yours.
thanks for the info but to be honest with ya i didnt see anything that looked like a vacum line:confused: i need pictures:( :D
