Help Reverse Wire 02 ls need to tap it???
Flame3g
Fairfield
hey fellas i need to find the reverse wire so i can hook up my rear view camera. i tap the green one and it turned on but it didn't switch back really need help on the guys:confused:
where did you find that green wire? When i was an installer we almost always went straight to the light it's self. It was usually a bigger pain in the a** trying to find it up front. I would just go to the light and meter the two wires. Also you might want to check to see if you have to switch your deck over to the rear view. I dont remember but i think that is usually the case. If you want i can try to find the wire on direct techs.PM me.
it may also be an issue w/ground vs. power switching. you might need a relay.
i don't think so i found the park wire and the D4 wire. that means i keep touching wires and found the park wire the camera was on when i pushed in my button to shift the camera swithed back to my dvd player. i need to know were is the reverse wire. My deck switches i just need to know were the wire is because i can't find it:confused:
I was thing of getting the same thing installed on my car. I have a new kenwwod deck that i will be using it on. How much was it? Where did you install it? Can we see some pics?
if u are talking about the camera im buying the one that is built into the license plate frame there on ebay they go for about 148. I will post pic when every thing is complete
