Help, running Amp power wire
MarkOfDeath
IL
Im running the Power wire for my new Amp, and I need to know how to get through the fire wall w/o drilling, I ran wires before but I went throuh the fender then into a hole between the door and fender
You can run it through the driver's side of the firewall, like right behind the strut tower - that's where I have mine going through an existing grommet. If I had a picture of it I'd post it for ya, but I don't. Sorry.
I figured that out, now how do I get the RCA cables from the glove box to the stereo, its a real tight fit, thanks
well its hits hard, my lights dim alittle so i will get a capaciter
if i were you, i would get a volt gauge installed as well. do NOT rely on the idiot light and or the message center! trust me on this.
dude, Im wayyyyy ahead of you, I got one about 2 maybe 3 years ago, I read 13.4-13.7 with the bass slamming in park
The stock amp in the rear has plenty of power to run an additional amp thats what I used then I attached the amp to the underside of the rear deck. looks stock.
I figured i would share how i ran my power wire. I found a wire harness boot seal (black Rubber) on the fire wall and ran it through that. I also did the same for my brothers 2001 lincoln navigator. The power wire came out just above the brake pedal in both cases. no holes being cut or wires running outside and then back inside the vehicles. I have done this also with my 93 cadillac seville that i sold a few yrs back.
Thats my 2 cents lol..
