I got a strange problem. A week ago, my lincoln ls 2006 V8 got an engine light on, and the code was P0355. I borrowed a scanner and tried to clear the code since I like to see if it comes back. The problem is when I put the ignition to on (engine not started), and press the clear button, the car suddenly went wild and cannot start any more. it looks like the anti-theft system is triggered...
I have dealer looked into the car. They replaced my battery and uses their programmer (a dealer laptop) to clear all the DTC code. These codes indicate the PCM cannot communicate with some subsystem, like ABS and track control. These maybe due to the battery.
After clearing the codes, the car returns normal and can drive without a problem. but when reconnect the programmer to the car and read the DTC code, they all come back! it looks like the code cannot be erased or it was erased but come back. The fault lights in dashboard are not lit - I assume the self check on start up passes. But why these codes still there? Can I say, as long as the dashboard does not tell any problem, it should be good and these code are just previous codes not erased properly? any thoughts?
Thanks a ton!
Thanks a ton!
