I had a "pro" do an engine swap for me. I have the car back after a "year" and it is setting codes 1235/1237
Particulars
2002 Lincoln LS
Engine V6 - engine came out of 2001
The car sat for a year (was running before engine death) has never run since.
Engine cranks but doesn't start
PATS light is not flashing
I do not hear the fuel pump(s) run when I turn the ignition to run
No pressure at the fuel rail
The "pro" told me the fuel pump fuse was blown and he replaced it
The car is setting a p1237 and p1235 which appear to be related to the fuel circuit
Could this be bad fuel pump(s) or is it more likely an open circuit somewhere?
What is the best way to check that there is power to the fuel circuit all the way through?
Thanks
Scott
Particulars
2002 Lincoln LS
Thanks
Scott
