Help!!!!!!!!!!!
95Marklll(Kingcobra)
Hernando
I just went into my car turned it on and evrything is fine. Then i turn on the ac it slightly revs done. Then after a while i see white smoke coming from the back tail pipes. Then I turn off my car look back and see water driping out of my pipes. :q:q:q:q!!!!! What the :q:q:q:q happen
The oil is clean I just read a mustang thread and a guy had the same thing he says its ok the water is clear so its fine i guess
Its called "cold exhaust pipe". The smoke you see is the water vapor from your catalytic converter. Thats also where the water comes from. Your not used to seeing it. I believe it was 50 something degrees this morning. ONce the exhaust pipe heats up, you don't see it anymore.
That makes alot of sense right know its like 60 outside. Ive own the car for like a month so I never experienced colder weather with my car. Thanks alot I was freaking out thinking i needed a new motor someone told me that if you find water like that your motors on its way out, A$$ hole. Thanks alot guys
