Help
zexls
MESA
Does any know the best tire size for a 18x8 wheel ?
I'm running a 36mm offset, which sticks out to begin with. I also run 255/45R18's, and they rub. I'll be looking for a fender roller too. 245/45R18's should be a safe bet, depending on the offset.
I have been running 245/45-18 size tires for quite some time now. I just got another set of tires today that are 245/40-18. I'm hoping these will help the rubbing problem I have with the car being lowered and low offset wheels.
True, it all depends on if you lower it. Mine is not lowered. It shouldn't rub with Ken's tires and no drop.
