Help!
buddyleee5
Ls ville
i was installing my amp today and i, like im assuming the rest of you on here found that the battery post is 7/16" and 1/2"... the biggest size i could find around here is 5/16". where did you guys get your battery rings for your amps?
i didnt put the ring ON the terminal. you put it on the screws that you tighten the battery down with. just unscrew the screw and slip the ring on and put the screw back on.
