Markus2
so i read up in some other threads on here about the issue of using the mustang set up, "sock" ????? when changing out fuel pumps in our marks.
so...
i also read that issues related to using "the mustang sock" in our marks will:
ISSUE ONE: lead to fuel starvation issues when turning our wheels and going to accel. out of the turn, the engine will almost stall out and than within a sec or two come back to life.
ISSUE TWO: fuel starvation issues when WOT off a ramp on a straightaway for example.
***THIS ONLY HAPPENS When using the mustang SOCK and in combination with our fuel tanks being at approx. 1/4 or less in quantity.****
____ALL OF THE ABOVE HAS BEEN GATHERED INFO. FROM OTHER THREADS HERE IN THE MARK 7 FORUM________
so my question is:
when i make lefts i notice the surging issue; and sometimes under WOT. AND only when i have approx. 1/4 tank or less.
my fuel tank is leaking, its rotted out.
Just got new tank, straps and 190 pump
*(pump and kit came from Auto Performance Engineering-this site was recomended in the same thread where i gathered the above info. on fuel pumps)
so i am about to install (well my mechanic is
) the pump and tank...
Going into this my concern is that what does the sock look like and how can i tell if the sock in my tank is from a mustang.
In the pump i got, the list of parts does not list a sock.
I am very very confused.
Guidance Please!!!!!!!!
Dont want to use the wrong sock again-and in the thread that said to use the site i did, AEP being the site, said to use that site specifically because they have the correct sock.
where is the sock.
what is the sock.
Im a lost fool.
so...
so my question is:
where is the sock.
what is the sock.
Im a lost fool.
