Help
barbrich
largo
i have put over 500 dollars in car repair alone in the last 2mnths. i finally got my car able to get started and now it is messing up again. i simply want to know how to get the car started and why wont it start right! when i start it it sounds like it is seized but upon cont to turn and hold ign it starts although today a cloud of smoke came out of engine smelt electrical please someone tell me what it is!:eek:
Sounds like the wires to your starter/battery are corroded. Corroded wires require more amperage and that usually results in melting wires:p
Sounds like one or more cylinders are hydro-locking from possibly coolant entering cylinder. I would pull the spark plugs and look at them very closely. If your using coolant in a particular cylinder that plug will be very clean. The electrical smell is the starter burning up. You should NOT hold the starter on if your engine is trying to compress water.
