alm450
After driving my 91 Mark VII around and burning up a bit of rubber something has started to happen.
My oil pressure light starts blinking at idle!
This only happens when engine is in normal operating temperature, and at idle at stop lights, signs etc. If I turn the steering wheel the rpms drop to 500 and light comes on almost steady.
Idle is about 750 when at a stop light, I've changed the oil (5W30), and checked it to make sure it wasn't burning oil and it isn't. The power steering fluid was a bit low so I topped it up, and it seems ok, other than the fluid being a bit murky.
I took a peek at the pcv valve and it still rattles, I didn't take out the screen, engine was kinda hot to be mucking around in there.
It doesn't do this when cold, only after it's been running for a while, and more often if I've taken it for a good speed run, It doesn't really do it on a leisurely ride home.
Any ideas?
Thanks
Any ideas?
Thanks
