LsPlayboy18
When im driving if i step on it my rpm's go up and my car sounds like its speeding up but im not. im guessing that the problem could be sparkplugs. spark plug wires or fuel injectors. Any one had this problem before?
As for the problem.......not enough information for me to give you a good reason. You might consider being a little more specific such as stating your cars mileage (mpg), idle behavior, any CEL's, etc. But one thing I know for sure is that it isn't spark plug wires as the LS does not have spark plug wires.LsPlayboy18 said:When im driving if i step on it my rpm's go up and my car sounds like its speeding up but im not. im guessing that the problem could be sparkplugs. spark plug wires or fuel injectors. Any one had this problem before?
victor_vera said:I feel like Im having the same problem, my car is a lincolns ls, v6, manual shift, 74000 miles also feel like the rpm's are going higher than before and that the acceleration is not as strong as it once was, the car does not shake or anything the idle is so quiet it feels like the car is off, no vibrations, I recently had the clutch replaced maybe about 3-4 months ago, sometimes it feels like the car has the power but then sometimes it just seems sluggish, any ideas what can be causing this, ohh and my Mpg's are not that great.
when i was watching the man fix it when he pulled the coil pack out it was covered in oil so when i seen that i knew wat happenedvictor_vera said:how do you find out wich coil pack has gone bad, can it be tooken off and checked?
are you low on gas when it happens???victor_vera said:the clutch seems fine, there is no smell to it the shift is smooth I just noticed yesturday while on the highway that when Im in 5 gear at about 85-95 mph i would say about 3500-4000 rpm the car seems like it misfires kind of like a shaking effect every second or so , I dont think its the clutch like i posted in a previous thread the car died on me last week while driving like it had no gas, It would start but idle very rough and couldnt get it to rev up. After I got it towed home I tried starting it a few hours later and it started and seemed fine, Ive been told that the fuel pump might be going out and doesnt have enough pressure, any ideas on how to check if the pump is going to give out
LBK_LS said:would a pack throw a code when oil is getting in? or do you just have to open her up and take a look for yourself. how often should those gaskets or covers need to be replaced?? i replaced my spark plugs at 50K, and they had oil in them.. cleaned it out real good, but haven't looked since. I've noticed a lack of reaction time, but when it does kick in.. VROOOOOOM!![]()
DLS-NYC said:Took it into the dealer, turns out everything was peachy, must be losing it.
