I washed engine yesterday let it dry off sprayed on some plastic conditioner on hoses etc... It started up fine I drove around a bit and parked it. Started it up a couple of hours later drove to a friends house. Several hours later I started it again drove home it was fine. Today drove it to work at 7 was fine. Started it up to leave at noon and it was idling with a lope or (bump) and was hesitating when driving. Eased as rpms increased but clearly less power and not running right. Could the wash not cause a problem till a day or so later? Also there was a odd sound comming from either the alternator or small steel round regulator of some sort right in front of it. There are a few hoses going to it maybe a fuel pressure regulator, not sure. The noise was mostly at idle and when revved it would go away then come back a few seconds after returning to idle. The noise hasn't occured today could it be a fuel problem that happened to occur after I washed it? I also took all the cops off sprayed the plugs a bit with wire-dryer and the cop (ignitors). Also ran some seafoam through the car and reset the battery to no avail. Also no engine light.
