mrzeee
Hi All
Ford in all of its wisdom has decided to release the complete 97-98 headlight WITHOUT the HID bulb. It should be available by the end of june. The replacement HID bulbs are still a long way off, maybe November or December. Pricing on the headlamps is still to be determined. At least those with a broken or worn lens will be able to replace that, and have use of the high beams.
Ill keep you all informed if the HID bulb should become available.
Max
Max
