I have a 1995 deville 4.9 that has a high idle. when this happens the check engine light comes on. The wants $80 for a dianogstic. What could be the problem.
Invest in a code scanner, for about the same $80, you can diagnose as needed. How many miles does it have? does the high idle ever "kick down"? When is the last time the timing belt was checked?
Second, you don't need a code reader! Press OFF and WARMER on the climate control center, the codes will display. Write them down, and then have a look at this list. If you have a problem, it is most likely the ISC motor.
