DaleGrib
Is there really any difference between them?
No oil leaks other than the valve cover gaskets! Which won't be leaking much longer my new set of gaskets arrive on Monday. I have also recently dropped the oil pan and cleaned it up and installed a new pan gasket.Some say there is. I haven't noticed any difference with certainty. If there is, it's pretty marginal.
If you have no oil leaks now, I certainly would not use the high-mileage oil! It might speed up the onset of leaks.
