Sparkplug70
First I want to thank all , mainly Joey , for the correct advise on the problem with my 04 Ls. So it is to no surprise I am here with another strange one to fix. I pushed the set button 2 to exit the car and the horn and the electric tilt when crazy. The tilt went up,down about 2 times and the horn stayed on until i was able to disconnect the battery. It took almost 3hrs to be able to finally hook up the battery. Un able to get the horn to stop i just un plugged it . The tilt is stuck all the way down and will only move up just a little before it goes down back to bottom if you have the button pushed up. All other buttons on the wheel work. Radio,cruise settings and turn signals. All of this happened when I the #2 seat memory button on exiting the car. Thank you all once again for the help I have always received on this site.
