67Continental
When I pulled my hood release tonight, all I heard was a sound like the cable moving, but the hood didn't pop. How do I get the hood open? This Sucks!
Brozly said:Have somebody try lifting while you pull the cable...
Mine has gotten hard to pull since I crashed last March, hopefully I can get it adjusted.
ASMBLYLINE said:If anything you should PUSH DOWN on the hood while pulling the cable.
what does the handle feel like when you pull it?
My mark was completely deflated and on the ground and i was able to lay down and stick my arm up and release the hood.
JJ
JJ
Brozly said:Your probably correct, that would deffinatly be the case with mine,(cable pullin hard) but I have had some that would actually release and just not pop up...
