How Do I Change Fog Light?
LLLL
Long Island
OK OK OK
So I did a major search and I couldn't find out how to change my fog lights on an 04 LS. Please don't everyone bark at me all at once for asking. I am sure there is a previous post about this but for some reason I could not find it.
Any help would be great.
Thanks :Bang
LLLL said:
OK OK OK
Thanks :Bang
Are you trying to change the light bulb or the light assembly?
If you are just changing the bulb it's very simple. You'll have to get on your back to do this but locate the fog light plug behind the assembly. Press the release tab to unhook the plug. Once you've done that just twist the bulb out and you can replace the bulb. Snap the plug back in place and your done.
I just needed to replace the bulb. Thats all the info I needed Thanks A lot. I dont have time to do it untill I get home tonight from the office and I just wanted to make sure it was an easy switch. I figured it was an easy job but since I am not going to have much sunlight when I get home tonight I just wanted to make sure.
Thanks again :wrench
