How do I remove sway bar bushings???
kdevore
Southern IL
Got the clunk in the front end. Put it up on stands and I can rattle the sway bar in the frame mount bushings, mostly on the drivers side. Is there some sort of trick to get to the bolts on this mount. I couldn't see any good way to get to them with out pulling the fan out, which I don't want to do. I think I can get the back bolts on each side but the front bolts look impossible. What's the trick????
kdevore said:
Thanks! I searched for "sway bar bushings" but it didn't return that thread. :confused:
I just happened to know that he did this a few mopnths ago and I searched using his name. I pratically live inside this place. It is like a seperate room in my house that disappear into :D.
When you find out please post the answer here. I need to tackle that job when the weather gets cooler.
