how do you remove the crank pulley
MarkOfDeath
IL
how do you remove the crank pulley and keep the it from spinning
You need a harmonic Balancer puller. To lock the engine in place, you have to pull the t/c shield plate, and lock the Flexplate with a screwdriver, or prybar.
I used an impact wrench and a puller.....worked like a charm. (had to remove the fan/shroud also) :Beer
ya I removed the fan as well worked real well thanks anyways tho
IMHO, I would use an impact wrench only as a last resort.
