young mark 8 lover
im debating on whether or not to take it out and sell it seeing it would be less weight and seeing that im staying with coils so im probably going to pull almost all the remaining air ride parts i can
Why is your car coil converted? Did you do it? It was likely converted by a previous owner because the system failed. Don't sell it unless you are sure it works. Compressor failure is the most common reason people ditch the air ride.
You just need to know why they converted. People usually prefer the air bags when the system is working properly. Something was probably wrong with it.
Why didn't you just put this in the same thread for the height sensors?
is it worth anything as it is im seeing it as the less stuff i have that aint needed the better since.im never going back to air ride plus im a weight freak at times
negligible amount of weight IMO, but ok.
and yes, its worth about $20 for a compressor with no history.
