How to remove fuse box cover navigator 2000
john19999
Chicago
I need to change fuse. The fuse box is near Steering wheel column (next to Brake pedal) The manual says open the cover. I could not figure out how to remove the cover. There are 2 screws on this box but not sure if I should remove these 2 screws. If you have ever opened the cover, please share hoe to remove the cover. Do I need to open the screws?
Thanks
John
Ford Nut,
Thanks. I tried to search the forum that you mentioned but could not find the information. I will higly apprciate any information as how to open cover of the fuse box.
Thanks
John
I have no idea.
Grab it an pull till something brakes :)
Join that forum, it is a good and busy place with people that have a truck like yours.
Your best luck is at FTE.
