How To Remove Iac
meangy9
jersey shore
I OWN A 95' AND CAN'T GET THE IAC OFF TO REPLACE IT. I TOOK THE TOP PART OFF THE THROTTLE BODY TO TRY AND MAKE SOME ROOM, BUT I JUST CAN'T GET TO THE NUTS ON THE SIDE. I ALSO TRIED FROM UNDERNEATH BUT WAS IMPOSSIBLE ALSO. ANY SUGESTIONS WOULD HELP ALOT. THANKS :Beer
Use an open end wrench on the bolt closest to the firewall, and a long socket/small ratchet on the bolt closest to the motor. Also helps if you undo the fuel lines, and move them out of the way. The bolt closest to the firewall is fun to get out though. There'll come a point where the wrench will hit the firewall and you're stuck getting the bolt out with your fingers.
I had mine out to try and clean it a month and a half ago, and it was a huge pain to do. A few weeks later I put in a new one and it was a piece of cake. Once you figure out the right angles to get your hands in there, it's not that bad. I suggest using a little RTV sealant to hold the new gasket to the IAC when you go to re-install it.
Good luck.
hey thanks, I appreciate it alot. hopefully it'll be easy to do. I'm just gonna replace it instead of cleaning it. don't want to take a chance of having to do it twice.
I Never Really Moved My Fuel Lines Before And Am Nervous To Crack Or Break Something. So Are There Any Specific Ways To Move Them? Just Don't Wanna Run Into Replacing Something Else.
NICE # OF POSTS NYC. THANKS FOR ALL YOUR ADVICE, I'LL ALSO BE PUTTING IN A FUEL PUMP WHEN I GET BOTH OF EM. :Beer
