How to REMOVE the factory speed limiter ?
ljay99
Indianapolis, IN, USA
cheapest way 2 REMOVE factory limiter ??????
i have a 95 LSC MARK 8 WITH THE 4.6 32 VALVE.
has tons of power.
where do i go to have the factory governor REMOVED ?
ALSO, why do they have 2 cats and 2 mufflers. when they Y the pipe down to 1 pipe in the middle ? isn't only going to flow as well as the smallest point ?
Ljay99@hotmail.com
A chip will remove the limiter. The factory exaust is restrictive and replacing it is a worthwhile upgrade.
2 cats and 2 mufflers on an LSC is better than the 3 cats resonator and 2 mufflers on the non LSC models...
Search the Mark VIII forum for examples of different exhaust set up.
To remove the speed limiter you need a chip.
wouldn't it "Disable" the limiter not "Remove" it? :D
Since the limiter is a function of the chip, it would totally remove it;)
You cant "Remove" a function you can only "Disable" them EVERYONE knows that :p
The "function" is a part of the program of the chip, and when you replace the chip you remove it from the car. It has to be available to disable it.
tou che
