Hi guys, i tried to search everywhere on how but i can't seem to find any info so i decided to make a post.
Both of my front inside door handles snapped, don't really know how. But i had an idea to try and swap the back door handle with the front ones since rarely do people sit in the back. I noticed the handles are identical as long as they are from the same side as in left sides are the same, and right sides are the same, but when i took the door panel off and was looking for the door handles bolts or something i noticed it had some weird metal screw. It goes through like a regular bolt, but is then split down the middle into 3 pieces after is goes through, its hard to explain i might be able to post a pic of it. Am i supposed to break these to remove door handle? if i do then how do i put it back?
I've read other people have already had the same problem so there has to be somebody that know's what im talking about.
Thank you!
PS: it's for a 00'ls if it matters
Thank you!
