How to take out your headlights
Clean00LS
Clinton
How do you take out your headlights and find which color sealment you have to clear the corners on a 2000 Lincoln LS
If done right you really don't have to use any additional sealant on the headlights but you really have to make sure you get a good seal from the old sealant once you put them back together. I always use high heat black RTV sealant from McKanica which can be found at most automotive stores. I'll have the first set of clear and smoke turn signal lenses next week so if I were you don't waste your time on the flourescent lighting acrylic or similar. I'll have the real deal as a replacement. I've got the clear and smoke versions coming. These are a direct swap for the amber lens and no need to cut the acrylic sheets. Pricing has not been set on these as of yet.
As part of the angel eye headlight installation I offer the bezel painting. You can have it painted any code but I don't recommend it if you already have a black car. The bezel is already black.
