seionkelley
Ok, has anyone on this site re-drilled their hubs and rotors themselves? If so, do you have instructions on how to do it? Does anyone have a template that I can use?
Thanks
Thanks
I've only done the rear before when I put a MN12 IRS in the back of my F100.
The fronts are easier to just use Mustang hubs.
Just make a template. Measure the hub diameter, scribe circle, scribe bolt circle, mark off 5 equal distances. Drill out the hub circle, and drill the lug locations to 1/4". Knock out lugs from hub, set template on hub, center new lug location between old, use a 1/4" transfer punch to locate the new lugs. Drill, reinstall lugs..
Rotors can be done on the car using the hub to center the rotor and template. (Do this prior to reinstalling lugs. Mark, drill, and chamfer the backside of the new holes. (Match the originals)
Redrilling hubs now, have you ever worked on a car at all before???
I used a 3 jaw clamp then dialed the part in using the center hole
Then used the bolt circle program on the Bridgeport set to 5 X4.25
Its nice to work at a machine shop![]()
Work hell.... I have a mill and rotary table at the house...![]()
He based that remark on two things. One is the machine shop here would charge about $120 to redrill them and he feels (as I do) that it would weeken the hub. The other part is that I have shown him Cobra hubs for $80 each online before.Why not new cobra hubs for the rear go
for $195 now per side
So it seemed cheaper, safer and easier to buy Cobra hubs.
His comment was also based on the fact that front Mustang hubs are a dime a dozen and simple to swap so why bother drilling the front hubs.
snap......were do you live again....![]()
you don't need to mess with the front center bore at all. mustang and mark hubs have the same rotor center bore.
and if you use a redrilled mark rotor and redrilled mark hub, you also don't need rings. why would you? its the same combo. you just moved the holes.
